Questions on Quality.
Old Apr 24, 2010 | 03:42 PM
Fosnot's Avatar
Default Questions on Quality.
So while I've been saving up for the system, when it comes to quality -both construction and clarity- what brand of speakers -both coax and component- and sub woofer - 1 or 2 ohm impedance - are going to be the best?
80w -or 125w per channel @ 2ohm-, rms, on the speakers and 400w rms on the sub @2 ohm - or up to 600w rms @ 1ohm -
Old Apr 24, 2010 | 04:20 PM
cfallsguy's Avatar
Do you have a price range you're looking at for everything?
Old Apr 24, 2010 | 04:28 PM
Fosnot's Avatar
Nope, going for quality here. While I don't want to get the insane 600$ per pair speakers, 150-200$ per pair is not going to be considered exorbitant.
Old Apr 24, 2010 | 05:04 PM
99Bluz28's Avatar
Sub budget?
For you main speakers take a look at the following:
Focal, Morel, Rainbow, Diamond Audio, Polk, CDT .
Old Apr 25, 2010 | 12:04 AM
mrchyzy16's Avatar
I run all JL Audio. They are hands down, the best i have ever owned and heard. And i have listened to alot of speakers.
Old Apr 26, 2010 | 09:43 PM
Fosnot's Avatar
Originally Posted by 99Bluz28
Sub budget?
150-300$ - subs
I was looking at a pair of Infinity Kappa components for the front, and coax for the back
The sub I had yet to decide on, maybe a Alpine Type R, or or a Fosgate?
Old Apr 26, 2010 | 10:25 PM
cfallsguy's Avatar
You want an SQ sub? And assuming you'll be running just one sub, right? And the companies 99blu suggested are nice as well.
Old Apr 26, 2010 | 10:42 PM
Fosnot's Avatar
As of right now just one sub in a stealth box is my plan, and yes I'm going for sound quality, not necessarily quantity, but if it can be loud and play great thats definitely a plus! lol
Old Apr 27, 2010 | 02:53 AM
99Bluz28's Avatar
Take a look at these subs, all can be had for $270 or less.
10" Subs: Fi Q, ID IDQ v3, SSA Icon, JL W6 v2, Alpine SWX, Polk SR
Old Apr 27, 2010 | 09:13 AM
cfallsguy's Avatar
Also look into DC audio subs. They have level 3 12's that are a good SQ sub but also really hit and they're 600w/1200w max. I can get you contact info if you'd like.
It also depends on how much room you got for each sub, i don't know the exact dimensions of the stealths, though.
Old Apr 27, 2010 | 01:21 PM
99Bluz28's Avatar
Most stealth enclosures are only good for about .7 cu.ft., that would rule out all 12" subs I know of, and a lot of 10" subs.
Old Apr 27, 2010 | 10:53 PM
Fosnot's Avatar
Not to go against what has already been proposed, but what about the Rockford Fosgate T110D2, it fits my volume requirements and would go to 1ohm, and RMS of 600watts which would match my amp good...
This is the alpine I had in mind: http://signature.crutchfield.com/s_5...3D.html?tp=111
or maybe even this pioneer..
http://signature.crutchfield.com/s_1...D2.html?tp=111
Just looking at the specs on these anyway...
And as for the speakers, has anyone had any trouble or goood luck with the Infinity Kappas? Like these? http://signature.crutchfield.com/s_1...cs.html?tp=105 -for the front door-
and these: http://signature.crutchfield.com/s_1...9i.html?tp=105 for the passenger holes?
Or should I stick with alpine for the speakers?
Again, I won't be using the monsoon amp at all.
Old Apr 28, 2010 | 09:45 PM
Fosnot's Avatar
Yes??
Old Apr 29, 2010 | 12:41 AM
99Bluz28's Avatar
The RF sub will work fine in the stealth enclosure, but the Fi SSD (W/high qts)would still be a better option at $170, and would work great in a stealth enclosure.
IMO, no need to run all alpine, unless you want to, but I'd pick them over the Infinity Kappas. I run 7 different brands in my system, because that's how I got the results I wanted. Don't be afraid to "mix-n-match" brands.
Also, I'd run the RF sub or Alpine sub, long before the Pioneer sub.
Old Apr 29, 2010 | 01:29 AM
squee's Avatar
I decided to go with CDT's for my doors and sail panels. Couldn't be happier. While my front ones cost $999 new, they were well worth what I paid for them used. I've listened to ALOT of speakers, and nothing has ever had the clarity of CDT's. The only thing I'd go with over them, would be Focal or Rainbow. As for the sub, you can't go wrong with the Fi Q.
