monsoon sub addition
Old May 21, 2010 | 07:47 AM
2000 SS 315's Avatar
Default monsoon sub addition
im adding a sub and an amplifier to my monsoon system.ineed to convert the speaker wiring to rca and was wondering where is the best place to splice this in.also is there any where in the back of the car i can tie the remote on wire into.thanks in advance,scott
Old May 22, 2010 | 03:52 PM
sporttster's Avatar
https://ls1tech.com/forums/stereo-el...y-monsoon.html
And I would guess the remote on wire would be connected via the monsoon amps turn on circuit but not sure.
Old May 22, 2010 | 05:33 PM
Spartan7's Avatar
The monsoon amp does not have an on/off signal wire. It receives its signals through the actual speaker signal wires.
If you want to wire up a remote amp wire, your aftermarket HU should have a wire for it on the harness. You should just have to splice into that.
