Trans Am Seats in Firebird...
So far I've got the rears and the passenger side in with no issues.
I tried putting in the Driver side this morning and realized I had a problem.
The power connector coming from my car is much smaller (I think a 3 prong) than the connector under the TA seat (I believe 6 prong).
I had to reinstall my current seat since I didnt want to install the power TA seat and not be able to adjust it.
Also, the Pass. side TA seat has a power connector as well as a hose connector which I believe is for the lumbar support.
I heard I need to connect the driver's side hosing to the pass. side. I don't have any power supply/wiring/connectors coming out of the carpet on the passenger side. Do I need to buy a pigtail or something to make this work?
Any insight on making both sides work would be great.
Also, if there is a write up or install tips somewhere that I can be directed to, that'd be awesome.
Thanks.
Actually, I contacted Mark at hpsalvage and he has the wiring/tubing I need to make them work. He also has the carpet (as you know I'm doing the ebony swap) for sale so I'm thinking I might just pick it all up and do the carpet swap since I'll need to run the wiring under it anyway.
If you'd be willing to lend a hand, I'd sure appreciate it!
Driver's side: front/back switch worked. one of the lumbar switches worked. Other didn't seem to do anything.
Now, I got in the car to move it and the front/back adjustment still works great, but neither lumbar support switch works. Makes a quick buzz like it's trying but nothing happens.
Passenger side seems to work, at least one of the switches.
Any ideas?
