Help with system?
Old Jul 7, 2010 | 10:37 AM
99monguse's Avatar
Default Help with system?
My wifes best friend has a 1997 WS6 She had a sub box/amp installed several years ago. She had the car in her garage for the past three years. I got the car running and I'm in the process right now of detailing it; which by the way took me 3.5 hours to fully wash and clay....of course there was some alcohol involved too
Anyway...back to the point here, I haven't had a subwoofer system since I was in highschool all the way back in 1993ish! The amp isn't getting any power so I checked under the hood to see if it was even hooked up to the battery. There is a cable heading in the direction of the battery on the passenger side with a connector crimped on the end that would obviously connect to the battery cable, thus supply power to the amp and the is somthing that the cable then goes into and comes out the other side; its clear plastic and its about 3-4 inches long. This micht be a fuse holder, but I'm not looking at it right now since I'm at work. When you look at it the middle has a very thin wire in it, somewhat resembles in inards of a light bulb...what is this? I am thinking whatever it is, it needs replacing because there electrical tape on both ends and one ends is broken. She said when the stereo worked it would sometimes cut in and out.
Old Jul 7, 2010 | 06:45 PM
bigairboarder44's Avatar
You're describing the inline fuse. It's the top right thing in this picture:
If there is electrical tape on it, I'd say it needs to be replaced. Most likely, it is either a 60 or 100 amp fuse, but it will be stamped on the fuse somewhere. Replace that, and you should be good to go.
Old Jul 8, 2010 | 08:11 AM
99monguse's Avatar
Yeah, thats it. Why its taped I don't know, they are really inexpensive. She said it would cut out on her and I'm figuring it was due to the fuse holder.
