Antenna problem
Old Jul 15, 2010 | 03:14 PM
Hondo99's Avatar
Default Antenna problem
The antenna on my T/A seems to get stuck sometimes. The Motor still works fine but it won't come down. After a couple of weeks it decides to work again. Any ideas? i got tired of it so yesterday it started working again and while it was down i unpluged it just got tired of fighting it.
Old Jul 15, 2010 | 09:08 PM
WhiteBird00's Avatar
Ungrounded Moderator
The mast is probably gummed up with road grime - a common problem. Extend the antenna all the way and then thoroughly clean the mast with mineral spirits. That should solve the sticking.
Old Jul 16, 2010 | 11:48 AM
GSus's Avatar
just clean the outside of the mast?
Mine got stuck about half way, I can still hear the motor trying to go up and down, but doesn't move at all. I think I can extend the antenae all the way up, just not down.
Old Jul 16, 2010 | 12:34 PM
GSus's Avatar
Well, mineral spirits as well as a light coat of lube is a no go for me. I think the mast strap is broken. Guess it's time for a new motor
Old Jul 16, 2010 | 04:49 PM
wssix99's Avatar
Save the manuals!
it's from the paint on the mast. You have to use 100% mineral spirits to dissolve the gummed up paint and cycle the antenna a couple of times. If that doesn't work, you can just replace the mast only. The motor is probably fine.
Old Jul 17, 2010 | 10:13 AM
Hondo99's Avatar
Thanks alot guys ill try it this weekend
Old Jul 18, 2010 | 04:05 PM
ukg35's Avatar
I got mad at mine and took it out. Got a amped rubber antenna. I think it looks ok, but glad I don't have to mess with the power one anymore. plus weight reduction! haha
