Security Light - BCM question
Old Jul 17, 2010 | 10:22 AM
celalabama's Avatar
Default Security Light - BCM question
I have a question, my security light has been on lately and last night when I locked the car the radio did not go off, it stayed on all night. Is it a problem with the BCM or something else? Don't really have any other symptoms. Any help would be appreciated.
Old Jul 17, 2010 | 07:45 PM
silver-ss's Avatar
i have the same.. put my ARS sensor/buttom doesnt work ABS is on, brake light, how would i make those go away
Old Jul 27, 2010 | 07:08 PM
randytj's Avatar
On mine when the car is running the security light is on and my radio-clock display is off.
When I shut the car off the radio-clock light comes on for a few seconds and then goes out???
Old Aug 2, 2010 | 12:12 PM
celalabama's Avatar
Got into my car this weekend and found the BCM (Code:UPL) and took it out. Found corrosion on the plugs and cleaned then up. Got into the BCm but couldn't find and bad solder joints so I put it back in. Also checked the ground points (both left and rt side in the kick panels) and they were tight and good looking. Guess I need to take it in to the dealer and have it diagnosed, probably do that this weekend when I go see my Dr. I don't have any of those other outward signs like th radio diaplay not working or other stuff. Just have the security light on the dash. I had the key checked and they said it was fine.
