Kee Audio Basic Speaker Package Installed Have A ?
So for the bazooka's to work right in your SS, you'll need to wire them in parallel to achieve the 2ohm load, as the factorys were.
I think you ordered the wrong package or just miscommunication, but it can still work.
http://a248.e.akamai.net/pix.crutchf...4-ohm_mono.jpg
They should be ok. It takes a bit of effort to cut the foam on those as they are treated and not just plain foam. It still doesn't sound like they are seated well. If there is air escaping from the sides then they will not sound right.
Keep me posted.
Keep me posted.
Dan
It is applyed by removing the speaker, peeling the backing off the Roadkill, and applying it across the opening of where the speaker goes. You then cut out the hole where the speaker mounts and reinstall the speaker back into the opening.
A good way to see how deadener works is to do the symbol test. I have done this. You can take a symbol from a drum set and put a small square of the deadener on it and it kills the sound a symbol would make. The point is you don't have to cover the entire symbol to deaden it. It is just enough to kill the vibration the symbol would make which is what makes the noise it makes. Literally it goes from making a "crash" sound to making a "tink" sound. Obviously for killing road noise this technique is not the way it works but for killing the vibration caused by speakers it works.
