Steering wheel lights
Old Aug 1, 2010 | 02:20 PM
ssteven's Avatar
Default Steering wheel lights
I no longer have a stock monsoon radio but still have the steering wheel controls. How do I turn the lights off? What wire to cut if thats possible?
Old Aug 1, 2010 | 07:15 PM
transsam's Avatar
Most aftermarket head units can be adapted to continue to use the controls. If you want to kill the lights either way, the easiest way is to pull the switches out. Gently put a flathead screwdriver between the button and the steering wheel and, again gently, pry. The buttons come right out with a little wiggling, prying and some finesse. Disconnect the harness that plugs into the rear of the button. Now take the button apart so that you can pull the bulb out. Done and done!
Using steering wheel controls with aftermarket head unit
Killing the bulb inside the buttons.
Old Aug 1, 2010 | 07:25 PM
ssteven's Avatar
mucho grassy ***
Old Aug 2, 2010 | 07:42 AM
wssix99's Avatar
Save the manuals!
I believe they have their own fuse. Just take the fuse out...
Old Aug 2, 2010 | 08:55 AM
WhiteBird00's Avatar
Ungrounded Moderator
You're right. There are two 1-amp fuses in the fuse panel labeled STG WHL CNTRL - fuse #3 is for the switch function and fuse #13 is for the switch illumination.
Old Aug 2, 2010 | 11:18 AM
transsam's Avatar
I gone and gotted myself owned!
Good info guys.
Old Aug 3, 2010 | 08:27 PM
428 78T/A's Avatar
99T/A. Left steering wheel lights works, right doesn't. Is it possible to open up the switch without breaking it to hell and back to change the bulb?
Old Aug 3, 2010 | 09:37 PM
wssix99's Avatar
Save the manuals!
I think there are several bulbs. You may want to check the connector behind the airbag - in the steering wheel first.
Old Aug 3, 2010 | 10:13 PM
96silverram's Avatar
It's actually very easy to open the switches if you take your time and use a jewelers screw driver. I have completely taken apart used and new ones with no problems when re-installed.
Old Aug 3, 2010 | 10:30 PM
428 78T/A's Avatar
No Im talking about the one behind the volume button.
Old Aug 3, 2010 | 11:31 PM
wssix99's Avatar
Save the manuals!
Ah - you just need to solder a new one in. There is a really good post somewhere here on how to do exactly that. Depending on if you have the old design or new design board, the soldering will be easier/harder.
