Adding an AUX port?
Adding an AUX port?
Im about to buy and adapter, what will i have to do to make this work? (GM9-AUX)
(non-sponsor link removed)
Not much... it's very easy. Pull out the head unit, plug the GM9-AUX adapter into the CD changer port (9-pin port with a black connector in it), plug in a patch cable to the RCA jacks on the adapter, and re-install the head unit.
Depending on what you're trying to connect through auxiliary input, you will need a patch cable with the correct plugs to make the connection. The most common use is for an MP3 player or satellite radio which requires a cable with a 3.5mm (1/8") stereo headset plug on one end and a pair of RCA plugs on the other end. These cables are available almost everywhere - Radio Shack, WalMart, etc.
The cable has a pair of RCA plugs on one end (one red and one white for right and left channels respectively) and a headphone style 1/8" mini stereo plug on the other end.
