Wiring up door speaker and separate tweeters?
I have some 6.5 and separate tweeters given to me as a gift. Curious about the wiring. There are 4 wires going thru one plug. I need to cut the plug to install the aftermarket 6.5s and tweeters. I believe I two wires are from the amp and the other two straight for radio, and the wires out of the radio are the ones i can use for my tweeters?
Ungrounded Moderator
All speakers are powered by the amp in a Camaro - only Firebirds have the tweeters powered by the head unit. Otherwise you are correct... one pair of wires is for the mid and the other pair is for the tweeter. You'll find the wire color codes in the Monsoon FAQ sticky.
