Proximity based alarm system..Plus push button start?
Old Jun 1, 2011 | 11:42 PM
  #41
emenny81's Avatar
Originally Posted by squee
Link?
http://forums.corvetteforum.com/c4-t...rt-review.html
Old Jun 1, 2011 | 11:44 PM
  #42
emenny81's Avatar
Link?
Looks like lassokey is out of the question their site is no longer working.
Old Jun 2, 2011 | 01:13 AM
  #43
squee's Avatar
Doesn't really matter. I'll be going with a Advanced Keys RFID/pushbutton setup most likely. I like the size of the access key, and the fact that it also has credit card sized emergency access cards.
Old Jun 2, 2011 | 01:43 AM
  #44
emenny81's Avatar
That's not a bad price thanks for sharing, I'll read up on it tomorrow
Old Jun 2, 2011 | 01:51 AM
  #45
squee's Avatar
No problem. From what I've gathered, its one of the best, if not the best RFID on the market. Just need to figure out if and how you can integrate it into a REAL alarm like my Viper 5902.
Old Jun 2, 2011 | 02:08 AM
  #46
emenny81's Avatar
Big deal breaker is not being able to open the trunk from the remote, im reading thru their forums now so I can educate myself and dont ask a question that has already been asked before
looks really good though for the price.
Old Jun 2, 2011 | 02:50 AM
  #47
squee's Avatar
That doesn't really matter for me if I can integrate my 5902. All the Aux. and sensors for actual security would be the 5902, and the Advaned Keys would just be the RFID and tach sensing pushbutton start. The problem I've seen with most of the RFID setups is arming/disarming the actual alarm. Alot of the RFIDs have trouble doing it.
Old Jun 2, 2011 | 09:04 PM
  #48
bad_408_vert's Avatar
Squee , when are you pulling the trigger on this?
btw when you said that RFID systems have a problem able/disable the alarm...you mean if used in combination with a second alarm like you want to?
Old Jun 2, 2011 | 09:19 PM
  #49
squee's Avatar
Yea, sort of. The RFID systems I've actually found information on didn't have a output that would arm/disarm an aftermarket alarm system properly. One for instance could only cut power to the aftermarket alarm when the doors were unlocked by the RFID fob. Problem being, that when you walk away from it and the system locks the doors, applying power to the secondary alarm, the alarm will go off, cause as we all know, when a aftermarket alarm loses power and then regains it, it goes off.
As for when, I'm not sure. I'll probably get my 5902 installed and like I want it, then tackle this, but I'm still unsure if the Advanced Keys can arm/disarm the 5902 properly. I don't wanna have to leave all the security up to the Advanced Keys. Its just not sophisticated enough in that regard. I want my 5902 with backup sirens and batter, tilt sensor, glass break sensor, proximity sensor, etc., while also having SmartStart on my iPhone, so I don't have to have a fob at all, just the RFID in my wallet.
Good news though, is that I think the Advanced Keys setup might very well be able to disarm the Viper, since it has a starter control relay output. That might very well be able to do it. Hopefully...
Old Jun 2, 2011 | 09:58 PM
  #50
ok thanks...I 'll put this in the backlog until remote start feature becomes available.
Old Jun 12, 2011 | 11:06 AM
  #51
lemons12's Avatar
With the star keyless start... Say you are doing 100mph at the track and have a problem that needs an immediate shutdown, will the car let you kill it just by pushing the break in a bit and pushing the button?
Or... Could I still use my normal key method at the track that way there is less likely a chance of malfunction.
