Maybe a dumb ?
Old Aug 29, 2010 | 11:24 AM
98z8uup's Avatar
Default Maybe a dumb ?
I am doing my install, and can't remember which side is pos or neg on this speaker wire. Just want to make sure. Both sides are clear and one side has a red line going down the center of it. Thanks for the help. You can see some of the things I am install in this forum:
https://ls1tech.com/forums/stereo-el...l-power-3.html
Old Aug 29, 2010 | 12:35 PM
ChvyCruzen's Avatar
I'm not sure what it pos or neg could be, sounds like the red stripe would be pos. Why not take your voltmeter and take the ground from somewhere else and try the pos on the red stripe wire. If no voltage, try the other. It may not come out to be 12V but you would know. Take measurements with the unit off as well to confirm the readings.
Old Aug 29, 2010 | 03:18 PM
98z8uup's Avatar
I will give you a try. Thanks
Old Aug 29, 2010 | 03:58 PM
theskitztikwon's Avatar
is it the wire comeing from your head unit or amp?? it really doesnt matter wich one you use as + - as long as thats the way you got it hooked up most the time the BLACK stripe is negitive so not sure with was done with the RED stripe
Old Aug 29, 2010 | 08:49 PM
LE35thSS's Avatar
yea aslong as you got one particular wire as positive that same wire has to be positive on the other end and the same for the other wire.
Old Aug 29, 2010 | 11:38 PM
98z8uup's Avatar
Still need to get the speakers install. So I think I will try it with the pos being the one with the red line in it.
Old Aug 30, 2010 | 02:05 AM
FL Junkie's Avatar
hook it up and turn the system on. if it sounds really thin(out of phase) you know you got it backwards.
Old Aug 30, 2010 | 02:10 AM
98z8uup's Avatar
The speakers should be here on Mon or Tue thanks for the help guys.
Old Sep 3, 2010 | 05:51 AM
98z8uup's Avatar
No one has use this wire before.
Old Sep 3, 2010 | 07:32 AM
WhiteBird00's Avatar
Ungrounded Moderator
It makes absolutely no difference which wire you use for positive or negative - wire is wire. As was said earlier, just pick one to use as positive and make sure you consistently use it the same throughout your wiring. For example, if you decide to use the red stripe for positive, connect the red stripe to the positive output of your amp and to the positive terminal on your speaker. Do the same for every connection and you won't have any problems.
Old Sep 3, 2010 | 12:54 PM
98z8uup's Avatar
Thanks Whitebird00 and others guys.
