8 gauge or 4 gauge
Old Sep 7, 2010 | 01:23 PM
drew01ss's Avatar
Default 8 gauge or 4 gauge
I want to power a 150 watt amp, a nitrous bottle heater, nitrous bottle opener, and a nitrous system consisting of a n20 purge solenoid, relay for n20 and fuel solenoid, relay for bottle heater, relay for bottle opener, and power for a window switch off of one distribution block. I will power the n20 and fuel solenoid with a different power source. The amp has a 25 fuse in it, the bottle heater is protected by a 30 fuse, the purge solenoid uses about 10 amps, (3) relay coils at ? amps (less than five), a window switch at ? (less than 5) and a bottle opener at 20 amps. There's no way I will be using all loads at the same time, but I want to do it right the first time. Should I be using 8 gauge or 4 gauge to the distribution block?
Old Sep 7, 2010 | 02:04 PM
SSPerformance's Avatar
4 gauge will be ur best bet
Old Sep 7, 2010 | 11:18 PM
19blackSS98's Avatar
8 would work fine but 4 never hurt.
