blinkers not blinking
So I just bought this car a couple days ago. Last night I turned my lights on they didn't come on. I turned them off and on again and they came on. But my blinkers don't blink now. The light comes on but doesn't blink. Could it be a fuse.
Did you turn the lights on manually or are you talking about the auto headlights?
And for your signals, are you referring to them lighting up exterior wise or lighting up on your gauge cluster?
Yes I checked the blinker fluid. Gosh....lol
It is both and they light up inside and out but stay on. I've heard of blinking faster when one goes out but not not blinking at all.
Ungrounded Moderator
On our cars the turn signal will go on but not flash when a bulb is burned out. However, that will affect only the side with the burned out bulb. Unless you have bulbs burned out on both sides, your problem is probably the flasher (there is no relay in our turn signal circuits). Try using the hazard flashers (without parking lights or headlights on) to check for burned out bulbs. Walk around the car with the hazard flashers on and look for lamps not flashing.
A replacement turn signal flasher is less than $5 at any auto parts store or even WalMart.
