Double DIN or Carputer?
Old Nov 9, 2010 | 02:22 PM
kjcmusic17's Avatar
Default Double DIN or Carputer?
I really like the idea of having a touch screen interface in my car, but I don't know if one way is better than the other. I also want to hook up my underbody light kit to the touch screen so I could turn it on through that. I don't know if that would be possible with either of these, but if anyone has some insight, I would appreciate it.
Old Nov 9, 2010 | 06:37 PM
bad_408_vert's Avatar
carputer
Old Nov 9, 2010 | 07:56 PM
kjcmusic17's Avatar
Are you saying that a carputer is better than a Double DIN touch screen? Or that the carputer is way I could turn my light kit on through a touch screen?
Old Nov 9, 2010 | 09:55 PM
Carputer has alot of potential for the same amount of money.
Out of those two I 'd say a carputer would be able to control the light kit.
Old Nov 11, 2010 | 03:10 PM
kjcmusic17's Avatar
ok, if i go with a carputer, is there a way for me to still use my steering wheel controls? What about fm radio and power antenna capabilities? How can I power my tweeters since I won't have a HU now?
Old Nov 12, 2010 | 06:22 AM
squee's Avatar
Ok, first off, your gonna need to do ALOT of research since your gonna be in a little over your head apparently on the carputer. It WILL get a little overwhelming, BUT you can infact control the lights. Get a doubledin carputer setup from someone like Bybyte, perhaps with the optional amp built in. As for the lights, use a Fusion Brain. It'll control anything you want it to. You just have to make a plugin for your frontend for whatever you want it to do. Not too hard.
Old Nov 12, 2010 | 07:40 AM
WhiteBird00's Avatar
Ungrounded Moderator
Some double DIN head units such as the Kenwood DNX-71xx series provide additional touch screen switch controls. On the Kenwood, you can program the two additional touch screen control switches to be either momentary (for something like a garage door opener) or on/off (for something like lights). Certainly it would be easier to integrate as an audio system and you can keep your steering wheel controls.
Old Nov 12, 2010 | 11:51 AM
squee's Avatar
Oh, I forgot to mention you can also keep your steering wheel controls with a carputer as well. You can program them to do whatever you want as well.
Old Nov 12, 2010 | 03:10 PM
kjcmusic17's Avatar
I have a close friend that will help me with the carputer as far as hardware and installation. All, I would need is the optional amp to power my tweeters.
How would the steering wheel controls work still? The most I've seen with that, is someone who kept the HU in and put it behind the carputer screen, but the it only gave him was volume control, not seek control.
Old Nov 13, 2010 | 02:32 AM
squee's Avatar
Well what your gonna have to do as far as keeping the radio is get a USB FM antenna and use that, but you can program them using a peripheral device (can't think of the name off the top of my head).
Old Nov 13, 2010 | 03:16 PM
pentavolvo's Avatar
select kenwood dbl din have relay drive outputs to control things like ur lights
Old Nov 14, 2010 | 03:47 PM
Tbird232ci's Avatar
Head over to mp3car.com
That is a very comprehensive forum and website dedicated to car PC setups.
Old Jan 13, 2011 | 08:04 PM
Wildcat 68's Avatar
this guy did a great job with his carputer and now has steering wheel controls
http://sites.google.com/site/snootch420/pontiacpc
