Need help on my 96Z28
also I have just realixed something else....my car is a 96 and the engine i put in is a 95 lt1.I noticed on my 96 motor at the bottom of the front pulley their is a sensor there,i guess crank sensor or something,and on my new motor there is not.could this pose a problem?
Ungrounded Moderator
ok i got ya...what I did was just unplug the vats connector and put the resistor in on the side going to the bcm.and just left the orange wires unplugged.i tried puttin the resistor in from the top of the connector but it went back steady,so i spliced the purple and white wires and just wrapped the resistors around the part where i spliced and it went to flashing.so,ill try again for a better connection
Ok well I put the resistors in like you said,and I checked the resistance on them before I put them in and I was right around 7.56.My key read 7.50 on my volt meter so i got enough resistors to make 7500 or close to it and still nothing.Just starts and dies everytime.
Is the security light still on or flashing? When the security light is on solid it means the VATS system sees resistance that doesn't match it's memory. When the security light is flashing it means the VATS system doesn't see a resistor at all (open circuit). If the security light is off then your starting problem is somewhere else besides VATS.
#33
and my oil pressure switch is broken also,just kinda hanging there.I noticed it when I was putting the engine in but I was just gonna test fit everything and all but ended up starting it,so with this being broke and my gauge not showing any pressure,could that cause it do shut off??it's behind the manifold by the firewall.
#34
I finally checked it with a scanner I was getting MAF sensor and crank sensor,so i plugged in the MAF and then cleared it out and I have yet to get another code.Not sure about the crank sensor and all cause I dont have a plug down by the pulley like the other engine did
