How do I disable VATS with EFILive???
Old Nov 22, 2010 | 04:43 PM
The Dragon's Avatar
Question How do I disable VATS with EFILive???
The security light is flashing and the car will not start.
Those two white wires that read the resistor in the key must be bad.
I've been told that I can trick the PCM with a proper resistor placed over those wires but I wouldn't begin to know what to do to GET to those wires.
So ... how can I just disable this cylinder switch feature? The keys are fine. I just don't want, or need, this resistor-reading feature.
Thanks to everyone for any assistance!
Old Nov 23, 2010 | 07:43 AM
WhiteBird00's Avatar
Ungrounded Moderator
Can I assume that this thread is redundant since you found the other thread about VATS bypass?
Old Nov 23, 2010 | 01:37 PM
The Dragon's Avatar
Yes. Thank you
