Is the radio harness all I need?
Old 12-13-2010, 09:13 PM
destroyer1362's Avatar
Default Is the radio harness all I need?
I just bought an alpine ida-x200 off my buddy, but I don't have the harness that came with the hu. If I get a replacement from ebay as well as everything here: https://ls1tech.com/forums/2743520-post5.html will that be all I need? And what about the rca plugs in the back of the hu, will any of the harnesses have the plugs on them?
Old 12-13-2010, 09:46 PM
ries's Avatar
Once you buy the Alpine IDA-X200 harness you will also need the following:
Metra Pn's: 40-GM10 (ant adapter), 70-1858 (alpine harness to OEM harness adapter), 99-3300 (dash kit)
The RCA plugs running from the back of the HU are most likely subwoofer outputs, front/rear outputs and/or aux inputs. Try and download an instruction/installation manual for that specific HU. It will also help when you wire up the Alpine HU harness to the adapter harness. Hope this helps
Chris
Old 12-13-2010, 09:52 PM
That does help
Thank you
Old 12-15-2010, 05:48 PM
sjsingle1's Avatar
fixin to do a install in my car.............where can i get this stuff.......are all these PNs petra?
Old 12-15-2010, 07:10 PM
Cheap Guy's Avatar
Originally Posted by sjsingle1
fixin to do a install in my car.............where can i get this stuff.......are these PNs petra?
If you're patient and cheap, buy it online (eBay, etc.) Some even have the complete harness and mounting kit together.
If you want it right now, even most Walmarts carry at least the harness, and if that fails, you can get them from BestBuy (but it's gonna cost you a lot more).
Old 12-15-2010, 07:15 PM
sjsingle1's Avatar
is that wiring harness 70-1858 complete for wiring up a alpine HU to a monsoon system.......or is more needed?
Old 12-15-2010, 10:35 PM
ries's Avatar
that wiring harness will works with the monsoon stereo to your alpine HU.
It will come with tail ends for pos, grnd, acc, illum, front +/- L/R, rear +/- L/R, etc...You will have to splice or solder into your aftermarket HU harness
Old 12-16-2010, 02:15 PM
..and if your a perfectionist get some heat shrink tubing
Old 12-17-2010, 01:34 AM
sjsingle1's Avatar
i have plenty of heat shrink
Old 12-17-2010, 01:37 AM
sjsingle1's Avatar
went to wal mart and they did not have ANY metra stuff
Old 12-17-2010, 09:55 AM
Cheap Guy's Avatar
Looks like eBay is your best bet. Some sellers carry the complete harness/mounting kit, just make sure you get one with the flat face plate if you want it to look right.
Old 12-17-2010, 11:56 AM
Ungrounded Moderator
WhiteBird00's Avatar
The brand name is not important. Just get the GM 21-pin adapter harness for models 1988+ from whatever maker they carry - Scosche is another common one besides Metra.
Old 12-17-2010, 09:14 PM
sjsingle1 pm'd
Ok one more thing, everything is plugged in and working with my alpine hu but what did this plug do? It came out of the old hu but doesn't plug into anything now.
Old 12-17-2010, 10:10 PM
ries's Avatar
sjsingle1 pm'd
Its the CD changer plug if Im not mistaken
Old 12-17-2010, 10:30 PM
^weird, I have a 98. I didn't think they had that option. I know it doesn't have the 6 disc changer..
Old 12-17-2010, 11:29 PM
ries's Avatar
Im pretty sure that all monsoon cars were prewired for a cd changer whether they came with one or not...either its the cd changer or steering wheel controls.
Old 12-18-2010, 12:08 AM
Oh yeah I forgot about that, like the ASR wiring being in the harness even if it's not equipped with it.
