Air/Fuel Gauge Problem
Old Dec 17, 2010 | 02:25 PM
Formulals187's Avatar
Default Air/Fuel Gauge Problem
I have an Autometer Air/Fuel Ratio gauge that was installed 3 years ago. Recently the gauge stopped sweeping/reading; I realized that the O2 sensors crapped out. I replaced the O2 sensors (front) and now the gauge doesn't "sweep" like it used to, where it would sweep and then state whether the air/fuel was lean, stoich, rich. Could the gauge be going bad?
Old Jan 4, 2011 | 07:04 PM
Suggestions?
Old Jan 13, 2011 | 01:20 AM
cowboysfan's Avatar
A/F gauge should have one sensor per gauge, unless you got two gauges for each sensor. not sure what u mean by front sensor..... what is th setup actually?
Old Jan 16, 2011 | 10:58 AM
I have one air fuel gauge hooked up only to the front driver side O2 sensor. I had it reading only the passenger side for a while and then it stopped reading, so I moved it over to the driver side bank.
Old Jan 21, 2011 | 06:23 PM
Any other suggestions?
Old Jan 22, 2011 | 08:35 AM
98sscammed's Avatar
My a/f gauge keeps fouling out my o2 sensors
Old Jan 24, 2011 | 06:26 PM
Air/Fuel ratio gauges can foul out o2 sensors?
Old Feb 1, 2011 | 08:38 PM
Maximus0066's Avatar
do any of you have a how to guide on installing gauges? i have searched the forum but havnt found much
Old Feb 3, 2011 | 07:53 PM
98sscammed's Avatar
Yeah I wired in a a/f gauge and within 30 min I threw a code on the u2 I wired it on.
