Verifying wiring order for aftermarket head unit.....
I have a pioner DEH-3300UB head unit im putting in my camaro. At the same time im replacing all speakers and adding an amp and a subwoofer. Instead of messing with any of the monsoon wiring ive ran all new wiring throughout the car to each speaker, the amp, and the subwoofer. The only place ill be messing with is im going to splice the power wires off the factory harness (note: splicing off of, not cutting harness). Ive read the sticky but I want to verify im hooking this up correctly.
My pioneer harness has three "power" wires. A black ground obviously, a yellow constant hot power, and a red ignition controlled hot power. As far as the sticky goes it should be wired as such follows...
Pioneer Black => Factory Black (Ground)
Pioneer Yellow=> Factory Orange (battery power-for radio memory)
Pioneer Red=> Factory Yellow (ignition controlled power)
Is this correct?
Is this correct?
