Wiring questions
Old Jan 27, 2011 | 05:56 AM
dp.drift's Avatar
Default Wiring questions
Hi,
I'm putting an LQ4 into a 1988 RX7. I'm going to be using a Corvette dash, and switching a lot of it over to toggle switches. Currently I have an 2002 C5 Dash, the 2003 LQ4 engine harness and pcm, and a 2001 Trans am dash harness.
Is there anything I need to change over to get these two harness to work with each other? How about the Dash? Also, If i wanted to add the air conditioning controls from a GTO, or electronics from a CTS will I be able to use them, or modify the harness to accept them?
I'm doing a over the top street/strip build, and I'm starting to get pieces together now. I'm building a custom Kevlar/Carbon fiber dash, and I'm getting lots of ideas for different parts. I'll post final pictured when it's all together.
Thanks,
DP
