Airbag light is on, Steering wheel buttons and horn dont work.
Car is an 02 Trans Am. I bought it as a roller, and I knew that the previous owner had removed and reinstalled the dashboard to put the heater core back in..
So from the day I received the car, the steering wheel buttons and horn didnt work, and the air bag light is illuminated on the dash board. So without removing the steering wheel just yet, I am trying to see what to look for. It sounds like maybe something is unplugged? Or maybe broken clock spring (SIR coil). What do you guys think?
I tried to look up a price for a replacement SIR coil through the GM part number 26069709, but its not showing up.
Save the manuals!
1) Check under the dash to make sure the airbag, controls, etc. are all plugged in at the connectors.
2) Take off the airbag and look at the connections. All three have connectors under the airbag.
3) If the above all look good, you'll have to take apart the column until you find the issue. (Its probably not your clock spring... unless one isn't installed.
https://ls1tech.com/forums/general-m...mn-repair.html
