Double Din checklist
Old Feb 22, 2011 | 11:07 PM
cascadesys's Avatar
Default Double Din checklist
I know this topic has been beaten to death, but I just want to make sure I have everything I need and that this will all work. This is going in a 2001 WS6 by the way.
I plan to get the following:
-Metra Malibu/G6 Double Din Mounting Bracket
http://cgi.ebay.com/METRA-95-3302-CH...item22ed188faa
-6LE Bezel
http://6litereaterdesigns.com/store/...roducts_id=190
-Pioneer AVIC-Z120BT 7" display
http://www.pioneerelectronics.com/PU...on/AVIC-Z120BT
If I buy these things, will everything fit and be compatible? Thanks in advance.
Old Feb 23, 2011 | 07:37 AM
WhiteBird00's Avatar
Ungrounded Moderator
You still need a wiring harness adapter (unless you plan to butcher and splice the factory wiring) and an antenna adapter.
Old Feb 23, 2011 | 09:36 AM
SnakeStomper's Avatar
Do you have steering wheel buttons you want to keep functionality of?
Old Feb 23, 2011 | 02:44 PM
cascadesys's Avatar
If possible, I would indeed like to maintain functionality of my steering wheel controls. Would you guys be so kind as to link me to everything else I am missing, specifically the wiring harness adapter and antenna adapter?
Old Feb 23, 2011 | 02:57 PM
cemlsx's Avatar
this is the link for the adapter so you can keep your steering wheel controls , I dont know about the wiring harness adapter since I used the (butchering & splicing) on my factory ones lol
Old Feb 23, 2011 | 03:04 PM
Both the wiring harness adapter and antenna adapter are available from any auto parts store and even WalMart. If you order your head unit from Kee Audio he will include those items with the order. The wiring adapter is for 21-pin GM 1988 and newer and should cost around $10. The antenna adapter is to connect a GM antenna to an aftermarket head unit. It's a common item but I can't remember exactly how it's labeled.
For a Pioneer head unit you want the PAC SWI-PS adapter for your steering wheel controls. Prices vary but you can get it from amazon for $34.
Old Feb 24, 2011 | 11:09 AM
TransWS6Am's Avatar
Please post pics once you install the avic-z120bt. I had the Avic-D3 in my Trans Am and am upgrading to the Avic-z120bt. The PAC SWI-PS works great by the way!
Old Feb 26, 2011 | 09:59 PM
camaroboricua's Avatar
You should'nt need the metra kit for the g6. When you place your order for the DD bezel make sure to specify the opening size so it will have a close gap.
Old Feb 28, 2011 | 09:35 AM
legendarysouls's Avatar
Yea just got mine Thursdayish from 6LE and don't need that G^ piece just get some metal and bend it in L shape and pop some holes Bracket made
Old Feb 28, 2011 | 06:39 PM
DOUBLEDMODS's Avatar
Closed ex-Sponsor Account
NOPE diod not come from 6LE
It came from Double D Mods
Call me when your ready for the Firebird
Dennis
Old Mar 2, 2011 | 10:36 PM
mushroom281's Avatar
what size bracket do i need to bend up ? i dont have my unit yey and dont really know w what bracket i will have to fab up. does anyone have ant pics and demensions of theirs
Old Mar 2, 2011 | 10:56 PM
edobi21's Avatar
Man that is one nice double din. Gotta love pioneer
Old Mar 2, 2011 | 11:02 PM
The bracket should be about 5" long and 2" tall. The 5" section would get bent to be 4" next to the radio and a 1" tab to secure it to the dash.
Old Mar 3, 2011 | 08:34 AM
our C5 Corvette brackets we have that come with our Camaro and Firebird packages work just fine
Here is a few pics of them for you.
Old Mar 3, 2011 | 06:04 PM
^ If you dont use two screws along the side of the radio on those the weight of the radio could cause it to tilt some. Just make sure to use at least two screws on it.
Old Mar 3, 2011 | 07:29 PM
we have sent out hundreds of brackets over the years
Pentavolvo has installed products We have installed procuts and almost 1000 bezels sold in 5 years have installed products and brackets work fine.
On a Corvette you have to use the brackets on the bottom
on a firebird or camaro you can but them on top, bottom, one on top one on bottom. Lock washers are included and they will not move.
Old Mar 3, 2011 | 07:40 PM
pentavolvo's Avatar
never had an issue with the above brackets and one screw per side
Old Mar 3, 2011 | 09:17 PM
That would be why I said "COULD". I was just stating that it MAY happen. I personally would never use just one screw per side to secure a radio. But hey, whatever works for you.
Old Sep 25, 2014 | 07:48 PM
02BlueFirehawk's Avatar
I need a set of brackets Dennis (Double D) I sent an e-mail via the website regarding my bezel purchase.
