Key chip ?
Old Feb 24, 2011 | 03:01 PM
datenbrick's Avatar
Default Key chip ?
Anyone know what resistor they use for a 1994 Z28 ignition.Bought the car and the old owner lost the keys.
Old Feb 24, 2011 | 03:12 PM
alexus6798's Avatar
Call dealership and give them the vin. there are 15 different chips
Old Feb 24, 2011 | 03:15 PM
datenbrick's Avatar
thanks will do
Old Feb 24, 2011 | 03:33 PM
Shutdown Theory's Avatar
your going to have to provide the dealership with your proof of ownership also
Old Feb 24, 2011 | 05:37 PM
sjsingle1's Avatar
they can tell from the key also........if you had it
Old Feb 24, 2011 | 06:20 PM
datenbrick's Avatar
im the owner now, that part is easy,getting the dealership to do it. thats another?
Old Feb 24, 2011 | 07:02 PM
pentavolvo's Avatar
if they are less then helpful, just look at tables get resistors for each value and try em all, i think if u get it wrong you have to wait 15 min or something, so not the end of the world but still a pain
Old Feb 25, 2011 | 11:49 AM
wssix99's Avatar
Save the manuals!
So, I take it that you haven't picked up the car yet?
You'll need to have someone registered with GM as a locksmith to look up the chip code. They will have to do the same with the key code. It could cost you $50+ once you pay for the chip lookup, key code lookup, and have a new key made.
Old Feb 25, 2011 | 05:04 PM
datenbrick's Avatar
yea i bought it. 2 years ago as a roller just put the engine in it
Old Feb 25, 2011 | 05:17 PM
wssix99's Avatar
Save the manuals!
Oh - then you have other issues. A VIN lookup may not help you unless you have the same PCM that came from the factory. Did your engine come with a new PCM?
Old Feb 25, 2011 | 06:05 PM
datenbrick's Avatar
put a ls1 in it, took the vats out of the pcm,this is the 3rd one have done,1st ignition put in one.
Old Feb 25, 2011 | 06:59 PM
wssix99's Avatar
Save the manuals!
Cool - So if you had the VATS disabled in the PCM, then you shouldn't need a resistor chip for the ignition, right?
If you don't have the keys, your best bet is to pick up a new ignition cylinder at the autoparts store and install it. (If you have the tools, it will probably be less expensive than having a dealer look up the key sequence for you.)
