amp wiring question
So anyway can it be done? I guess I have no particular reason not to run right off the battery but I'm just looking at my options here and I don't want to do something stupid as I've never wired my own amp. I'm honestly just trying to do the cleanest possible job and I see a few ways to really hide things on the drivers side of the engine bay.
Thanks a lot guys for any help.
You could really do it either way...that's just how I did mine.
am I overcomplicating this? is there any reason I shouldn't run my amp power from the positive lead by the fuse boxes that I posted pics of? If theres any reason I shouldn't let me know and thanks again
Was there a reason for wanting it on the other side? It can be done but I personally would not do that unless I had no other alternative.
The main reason I ran it on the passenger side is because I knew there was a grommet behind the PCM that would be big enough to feed the cable through without having to drill my own hole.
thanks for your response, based on that I will run direct from battery and through the firewall behind the PCM. I was just trying to figure out my options for a quick easy install.
does the PCM need to be removed completely in order to run the wiring? Does anything need to be removed inside the car or will I be able to access the grommet in the firewall by simply dropping the glovebox? any ideas how long this job should take a newbie like me? As you guys may have guessed I'm nervous and don't want to screw up but I don't pay to have **** done to my car. I always do all my own work and am very mechanically inclined just new to stereo stuff...always had friends who did it when I lived in so-cal but now I'm in Portland, Oregon and don't have those guys around anymore
Depending on how large your hands are you may be able to get behind the PCM without removing it. I had to remove mine to do it but it was a very easy thing to do just be careful with it as it does run your car basically...lol. The large grommet is right behind it.
If you remove the underside panel on that side you can get to the grommet without having to remove the glovebox. It can be accessed under and behind the glovebox. Also remove the door trim as it extends up and under that side of the dash where the kick panel is. You will need to remove it anyway to run the cable to the rear of the car if that's where you will be mounting it.
I have another post going as well where I asked about using the PAC-oem-1 but have seen no responses, do either of you have any experience with this unit? As i understood it, it goes between stock radio and stock harness and adds preouts for an amp/sub and would eliminate the need to splice wires for a normal line out converter. Do you know if this is correct or am i missing something?
And you'll do just fine on the install...when I saw the hack job that was done by a shop that installed my first setup, I decided it couldn't possibly be that hard, and I was right. Time consuming, yes, but not hard.
I just spotted your post a little while ago and had noticed you ran off the aux post like I had been thinking of doing. It does look really clean there which is why I had been pondering doing it in the first place. I'm not sure which way I'm gonna go now but it's good to know guys have done it both ways.
where did you bring the cable through the firewall? Did you drill a new hole or use an existing one? any pics by chance?
Thanks again to all three of you guys for helping me out
Sorry these are the only two pics I have of it right now, but in the bottom one, you can kind of see how there are no wires running up the side.
Suggestions... J-train or peterlawl84 as you've both gone this route
again thanks to all of you for making this whole job a lot easier
For a cleaner install, if you have removed your AIR pump, then you could run the wire down and into the space that the pump originally occupied (see my first pic in the previous post... the clean black wire coming from the aux post, it goes under the fuse box then comes back up into the space just to the right of the front fuse box). You can mount the fuse holder in that location to make it a cleaner install, I just left my fuse holder where it was placed originally.
When I ran my power wire in my Silverado, I just ran it with the wires going into the cab, just cut a small hole in the rubber grommet and slid it in. I am not sure if there is anything like this on the driver's side of the firebird though, I didn't look around too much.
J-train Btw, Love your car! I've always liked the yellow CETA birds best of all and yours is very nicely put together. The stereo install looks great as well, saw your other thread with more pics. Lookin good man!
