Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird How to Install a Double Din Bezel for Stereo<br>Step by step instructions for do-it-yourself repairs.
1994 Camaro double din install pics and info
Closed ex-Sponsor Account
I just finished up an install this afternoon on a 1994 Camaro for a friend.
Now that we know the process involved in the mods needed for the install we will be adding the 93-96 Camaro double din bezel to our website and taking orders for them.
We modified the stock radio bezel to allow us to put in the double din.
Radio used with this is the Pioneer 3300BT.
For the install process.
There was some cutting and trimming required for the radio to fit.
The top portion of the radio cage was cut out(larger plate shown in pic)
We also had to trim bits and pieces of the rest of the plastic inside the dash.
This pic will show everything we had to remove from dash to allow room for the radio
![Name: 110-2.jpg
Size: 2.34 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616864d1501350270-1994-camaro-double-din-install-pics-info-110-2.jpg)
This pic shows inside the dash after we cut out all areas that we needed to to allow for the new Pioneer to slide into place
![Name: 108-2.jpg
Size: 2.50 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616865d1501350270-1994-camaro-double-din-install-pics-info-108-2.jpg)
Next step was to make some brackets to support the radio
bracket for left side(driver)
![Name: 112-2.jpg
Size: 2.58 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616866d1501350270-1994-camaro-double-din-install-pics-info-112-2.jpg)
Bracket for right side(passenger)
![Name: 111-2.jpg
Size: 2.41 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616867d1501350270-1994-camaro-double-din-install-pics-info-111-2.jpg)
Front shot of brackets mounted
![Name: 113-2.jpg
Size: 2.55 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616868d1501350270-1994-camaro-double-din-install-pics-info-113-2.jpg)
Once brackets were made and attached to radio we wired up the harness and performed the bypass to override the saftey features from Pioneer
(not recommend by us for saftey reasons) and mounted and radio into the car
![Name: 118-2.jpg
Size: 2.38 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616869d1501350270-1994-camaro-double-din-install-pics-info-118-2.jpg)
And with bezel on here is some final installed pics
![Name: 135.jpg
Size: 2.43 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616870d1501350270-1994-camaro-double-din-install-pics-info-135.jpg)
![Name: 138.jpg
Size: 2.48 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616871d1501350270-1994-camaro-double-din-install-pics-info-138.jpg)
![Name: 148.jpg
Size: 2.41 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616872d1501350270-1994-camaro-double-din-install-pics-info-148.jpg)
![Name: 160.jpg
Size: 2.43 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616873d1501350270-1994-camaro-double-din-install-pics-info-160.jpg)
And there you have it
A 1994 Camaro upgraded to new current features for the audio
Car already had upgraded speakers, amps and corner sub box.
Here is a pic as well of the car this was installed in.
This is a Procharged 383 stroker motor with 700 rwhp
![Name: alan.jpg
Size: 1.11 MB](https://ls1tech.com/forums/attachments/wiring-stereo-electronics/616874d1501350270-1994-camaro-double-din-install-pics-info-alan.jpg)
We will be adding the new double din bezels for your 93-96 Camaro in next few days. Till then just call or PM us to order
Dennis
![Name: 110-2.jpg
![Name: 108-2.jpg
![Name: 112-2.jpg
![Name: 111-2.jpg
![Name: 113-2.jpg
![Name: 118-2.jpg
![Name: 135.jpg
![Name: 138.jpg
![Name: 148.jpg
![Name: 160.jpg
![Name: alan.jpg
Dennis
What kind of price range will these be... I've had a dbl din in my 96 camaro for a cpl years now but have yet to tackle the challenge of fixing the bezel so this would be awesome... spcearle@aol.com. if you could email me
If i send my bezel in to be modified then how do i get the modified brackets that you show in your install? I have a 94 camaro. Also where is the link for my car year? The link below is for the 97 camaro bezels?
Thanks
PS. Are you still doing this? Can I get my bezel modified for my 94 camaro?
Thanks
Hi are yall still making these bezels for the 94 camaro If so i need one. An do the brackets come with it?
