Security light issues!!!
Are you sure you installed resistors totaling within 10% of the VATS value? Actually, 5% would be better since the internals of the BCM also have tolerances that could cause problems if your values are close to the limits.
Ground out the TDR.
Cut the wire coming out of the BCM to the security light.
That is the only true way to bypass VATS.
And yes, very possible for BCM to be crapping out. My stock BCM did funky things and my new one has Radio issues at times.
