Window Problem
Old May 11, 2011 | 07:56 PM
1_bad94Camaro's Avatar
Default Window Problem
I've got a customer car and the driver window is rolling its self down. I've replaced the window motor and switches and it hasnt affected it. What do I need to look at or possible fix to resolve this issue. The car is going for a tune next week and I'd rather not haul it 4 hours down the highway with the window down.
Thanks in advance,
Steven
Old May 12, 2011 | 07:29 AM
WhiteBird00's Avatar
Ungrounded Moderator
I would consider the window express down module as a likely source of the problem. It is mounted in a pocket on the inside of the firewall behind the console just to the right of the accelerator pedal. You could try unplugging it and see if the window stays put. If so, a new one is about $75.
Old May 12, 2011 | 09:40 AM
I'll try that when I get to the shop this evening. I greatly appreciate it.
Old May 14, 2011 | 10:18 PM
I finally got a chance to test the express down module tonight. Turns out it was bad. Took one out of my cars and got the customer taken care of. Now to move on to the next problem. The nitrous controller isn't working.
