Antenna swap
Old May 23, 2011 | 05:49 PM
71novaguy's Avatar
Default Antenna swap
Don't know if anyone else has wondered this or tried it. But you can use the antenna from a 93-97 t/a on an 98-02 t/a. all it takes is swapping the stem piece that the antenna slids up and down in. just fyi.
Old May 26, 2011 | 05:09 PM
dahardon's Avatar
They have the same part #.
Old May 29, 2011 | 07:58 PM
71novaguy's Avatar
no they dont. these had different part numbers. the way the top piece mounted was different, and they used different rubber gaskets to fill in the hole at the fender
Old Jun 5, 2011 | 11:36 AM
kevindglenn's Avatar
It appears that they have the same part number...so, conceivably it should work.
