Right Turn Signal won't blink
Note: I just had the front turn signal lights replaced (both of them). It worked for a little while, then it stopped working.
When i turn on the right signal, the rear one turns on, but the front won't turn on. And neither will blink.
can someone let me know how to fix this?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
i made a post yesterday. Im thinking gm made the turn signal assemblys junk. My does the same thing. I have to keep a thing of bulbs, and when one goes i put another in and go. Could be a wiring issue, but impossible to find
Save the manuals!
To the OP - if you switch your left and right bulbs, you can confirm if it's the bulb or socket.
Both of my turn signal housings and bolb connectors were trashed. The housings were cracked, and the connectors were blackened and smelled like burnt trash. I took the housings out and sealed the cracks with clear silicone, then sprayed them with high-temp clear coat. I replaced the connectors with new ones I bought from Autozone ($8 a piece), cleaned the wire leads and assembled the connectors. After that, I installed the bulbs, and completely sealed the bases of the bulbs in the connectors with the clear silicone. No problems with them yet, and I did this April 2010.
