replacement Bazooka 6.5" DVC 4ohm sub in stock $89.99 shipped!
Are the Bazookas any good? It's hard to find replacements for the stock a 6.5" subwoofer. I'm going to buy a cheap set from a local vender, and have him repair the originals while I use them.
Any way, I'm good with a soldering iron, so I'm going to swap the plugs.
Do they come with a wiring harness where I can splice the cars wires together? Reason why I ask is because I have cut off the factory connectors and have them butt spliced to another set of speakers. I want to know exactly what I have to do before I get the speakers.
Closed ex-Sponsor Account
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
This is for speakers only
Thanks
Dennis
Ungrounded Moderator
If it truly is a base audio system (unusual for a Z/28) then the Bazooka subs would not work well. The base audio system has only four full-range speakers - doors and sail panels. You can use just about any full-range or coaxial 6.5" speakers as replacements. But check first that you don't have small speakers in the hatch area - that's the easiest way to recognize a Monsoon system.
There really isn't anything special about the "Monsoon" head unit - it's just a standard Delco radio like those used in dozens of other GM models. Some had the Monsoon label, some didn't. You can check for the UZ7 option code on your door sticker to confirm you have the 8-speaker Monsoon system.
#33
Anyone running an aftermarket amp with these? Been thinking about buying a little amp to send some power to my front components that I havent installed yet + some power to the existing bazookas I'm running.
#36
I will
I have 2 sets waiting to ship and 100 subs on order coming in sometime this next week.
So the order would ship same day they arrive to us.
We send out shipping info as well when all orders ship
Dennis
Dennis
#39
I got a pair of these for my birthday to replace the blown stockers. The previous owner of my TA had a Kenwood fold out dvd player installed. Anyway, its been a very long time since Ive heard the stock monsoon sail panel speakers, but it seems like these arent even noticable. If I really crank it up, then I can hear them. But at low volume levels, all I hear is a lot of highs. Very little, to any bass. This is with the bass turned all the way up on the Kenwood Eq. Anything else I can do to get some bass to the system, short of installing an aftermarket amp? Thanks in advance.
Second question/issue. If I adjust the fade to the rear just a little bit, is it taking away from the subs as well and giving more sound to the rear fillers? Or, is it taking sound away from just the door panel speakers? Right now I have it a R4, I just want to make sure that im not taking away from the sail panel subs.
Charlie
Charlie
