I Think Its Time.
Old Jun 18, 2011 | 05:26 AM
Mr.z/28's Avatar
Default I Think Its Time.
I think its time to replace the stock amp thats in the back of the car in front of the spare tire. for some weird reason, my radio goes on and off, on and off, and goes completely off, 2 minutes later it works again. Could this be the stock amp causing it to this? everything else is hooked up fine. What can it be? Have any of you ever replaced the stock amp with something better? Pics welcome.
Old Jun 18, 2011 | 08:12 AM
KEE AUDIO's Avatar
Sounds like the BCM. Do the windows still work when the radio turns off? Try and check that as I didn't realize the windows were not working when the radio turned off until I tried them one day while it was happening. The BCM is the most likely culprit and is a free fix.
If you still need another amp I have several very good ones that will work for you and run the whole system from one amp like stock but with much more power and clarity.
Old Jun 19, 2011 | 05:25 AM
Mr.z/28's Avatar
Im gonna sound like a noob, but what does BCM mean? The windows work somewhat ok. Motors will need replacing in the next month or two. What can I do in the mean while to prevent this from happening?
Old Jun 19, 2011 | 10:15 AM
WhiteBird00's Avatar
Ungrounded Moderator
BCM = Body Control Module. The BCM controls the Retained Accessory Power (RAP) circuit (among many other things) that allows the radio and windows to keep working after the ignition is switched off until a door is opened. A common problem is broken solder joints on the BCM circuit board that causes interruptions to the RAP circuit making the radio and windows stop working. This is entirely separate from the problems cause by worn out window motors - it cuts off all power to the windows and radio.
Old Jun 20, 2011 | 01:51 AM
Mr.z/28's Avatar
So what can I do? Is there a place where I can take it etc?
Old Jun 20, 2011 | 08:22 AM
You could do a search for "BCM solder fix" - there's a thread on here that has photos and complete instructions on how to fix the broken solder joints. If you've ever done any soldering, it's an easy and free fix.
Old Jun 21, 2011 | 02:00 AM
Mr.z/28's Avatar
no, never done it. I might have to find out someone that can do it.
