School me on Keyless entry.
Old Jul 20, 2011 | 10:53 AM
BlueBird346's Avatar
Default School me on Keyless entry.
Im planning on having a keyless entry system installed in my car, have a few questions.
Who makes the best ones, how hard is it to install, should I have an audio shop do it?
Thanks in advance.
Old Jul 21, 2011 | 07:19 AM
WhiteBird00's Avatar
Ungrounded Moderator
Doesn't it have factory keyless entry? Look for option code AU0 on the door sticker. Perhaps you only have to buy a remote key fob and program it.
Old Jul 21, 2011 | 07:26 AM
ramairetransam's Avatar
if you have power locks shouldn't the keyless entry be standard?
Old Jul 21, 2011 | 09:33 AM
I dont know, Ill go check. It didnt come with the remotes, but it does have power locks.
Old Jul 21, 2011 | 09:41 AM
Didnt see an AU0 rpo code.
Old Jul 21, 2011 | 11:20 PM
transam5.7lt1's Avatar
It will have a LED on the top cover of the dashboard, right between the grille/vent on it. There will also be a sensor on the back, by the antenna/spare. These are two key parts that will help you identify if it has a factory alarm. If it does, just get yourself a remote, program it and bingo!
Old Jul 22, 2011 | 07:23 AM
You may or may not have the factory alarm with keyless entry. If you have the alarm you most certainly have keyless entry but the reverse is not the case - it is possible to have keyless entry without having the alarm. The alarm RPO code is UA6.
Old Jul 22, 2011 | 09:47 AM
Im pretty sure it doesnt have either. The previous owner gave me two Viper remotes, but they dont do anything.
 Michael S. Palmer
Old Jul 22, 2011 | 01:09 PM
Try this:
1. Turn the ignition to RUN (do not start engine) then back to OFF
2. Remove the RADIO fuse.
3. Turn the ignition from OFF to RUN three times quickly (within five seconds).
If you have keyless entry and could program new remotes, the car will respond by locking the doors, unlocking the driver's door, and popping the hatch. If it does, buy yourself a new key fob from the dealer or ebay and program it. If it doesn't respond, you'll have to look at aftermarket kits.
In any case, turn the ignition OFF and replace the RADIO fuse to exit remote matching mode.
Old Jul 22, 2011 | 02:42 PM
Ok i'll try that. Thanks for the help.
