Bazooka replacements on 2001 Firebird
Old Jul 21, 2011 | 05:03 PM
Mb22's Avatar
Default Bazooka replacements on 2001 Firebird
My stock monsoon sail panel speakers blew out month or two ago and I finally found replacement speakers (Bazooka 6-1/2" DVC sub woofers) and I removed the old speakers and harnesses one month ago. Unfortunately, i lost one of the wire harnesses so i am just going to solder the wires to the new bazooka.
I have a couple questions before I do this. I am a beginner with audio systems, I have only installed a couple head units, never speakers. My brother moved several states away from me and isn't able to help atm.
The Bazooka's are DVC, do I solder all 4 wires to the one sub or just one set (TAN and RED for right speaker and WHITE and TAN for left speaker)? Since I won't be using a wire harness, I'm going to have to grab additional speaker wire to solder together so the wires could fit the mounted speakers.
I found this in the monsoon FAQ for speaker wiring
TAN - right rear subwoofer negative output
RED - right rear subwoofer positive output
LIGHT BLUE w/BLACK - right rear subwoofer speaker negative output
DARK GREEN - right rear subwoofer speaker positive output
WHITE - left rear subwoofer negative output
TAN - left rear subwoofer positive output
LIGHT GREEN w/BLACK - left rear subwoofer speaker negative output
DARK BLUE w/WHITE - left rear subwoofer speaker positive output
Old Jul 21, 2011 | 05:11 PM
Capricio's Avatar
All four to one sub, one pair of wires for each voice coil on the cone. It's a DVC (dual voice coil) cone. I would not solder the wire from the amp directly on to the speaker terminals. Just solder on a 16 AWG 18" length of wire to the terminals, with a male bullet connector on the other end. Crimp female (insulated) bullet connectors on the hot side coming from the amp. Then you have a quick disconnect built in and don't have to solder inside the car.
Old Jul 22, 2011 | 10:01 PM
Mb22's Avatar
just installed them today and they sound great, they have a good amount of bass
i had to drill some new holes because the current ones were to spread apart
they fit very tight so there is no rattling at all =D
thanks for the help Capricio
