headunit wont work
Old Aug 15, 2011 | 01:24 PM
ls1curt's Avatar
Default headunit wont work
well i just picked up a new dd and am putting my headunit from the z in it. it work fine when it was in the camaro but i just got it all wired in and now it wont turn on/do anything. i am getting power in the constant 12v. wire and the key on 12v power and i have a good ground. the fuse is also good in the headunit. anyone have any ideas what the problem could be? btw its a older pioneer super tuner IIID going into a civic
Old Aug 15, 2011 | 03:34 PM
Capricio's Avatar
Is there a reset button on it? Usually under the detachable face? You push it with a ballpoint tip or an unfurled paperclip.
Old Aug 15, 2011 | 03:55 PM
ls1curt's Avatar
na, theres no reset button at all on it.
Old Aug 15, 2011 | 05:33 PM
KEE AUDIO's Avatar
Is there no fuse inline with the yellow constant power wire? Usually there is an inline fuse in addition to the one on that back of the radio.
Also I would check the fuse with a multimeter just to be sure the fuse is intact. A visual is sometimes misleading.
