Windows and door locks dont work
Old Aug 26, 2011 | 03:27 AM
UnderConstruction's Avatar
Default Windows and door locks dont work
Okay so everything is fine and working but the windows and door locks the box under the glove compartment just clicks. Im thinking if anyone knows the wires ill see about jumping around the box or could the box be bad?
I have power at the fuse panel so im guessing the box to be bad any info would be great thanks.
Old Aug 26, 2011 | 07:53 AM
WhiteBird00's Avatar
Ungrounded Moderator
If you're referring to the BCM (Body Control Module) under the dash behind the glovebox, it controls the power locks but not the windows. It does provide power to the windows through the RAP (Retained Accessory Power) circuit but if that was the problem your radio wouldn't work either. It sounds like you have two separate problems.
If you bypass the BCM for the locks you will be giving up keyless entry.
Old Aug 26, 2011 | 08:19 AM
ISMELLRICE's Avatar
its more than likely the bcm...radio can still work just search for the thread on here and you should be able to fix it...just requires you to solder a few spots back up...
good luck
