Couple of good amp grounding locations
I'm probably going to mount my amp on the left (drivers side) on the rear flat deck behind the back seat. Any specific location on that side for a good ground point (cable is 36"). Also, on the other side in case I decide to mount it over there.
Ended up mounting my ground close to the rear drivers side seat belt mount. Gridded off the paint, cleaned up everything nicely, and stuck it right there. Did a resistance check with my multimeter, and got around 1 ohm between the ground point and the seat belt bolt.
