Engine to Chassis Ground
Old Sep 29, 2011 | 09:44 PM
bobbo489's Avatar
Default Engine to Chassis Ground
Ok, I was under my car today looking around and couldn't find it. Where is it located approximately? I am trying to do this before I finish the exhaust.
Old Sep 30, 2011 | 08:13 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Are you talking about the ground strap located behind the alternator?
Old Sep 30, 2011 | 09:34 AM
bobbo489's Avatar
If that is where the engine to chassis ground is, then sure. I am trying to do the big 3.
Old Sep 30, 2011 | 09:37 AM
dragonrage's Avatar
Just add a new one and leave the stock one alone.
Old Sep 30, 2011 | 02:59 PM
mrrman's Avatar
I cant even get to my braided strap on my 87 TA...its way to tight. Where would I add another one as you suggested.( where on the engine?)
Old Sep 30, 2011 | 03:20 PM
dragonrage's Avatar
Use an alternator (or alternator bracket) bolt and go to whatever sturdy point on the frame/chassis is easiest. Make sure to clean both surfaces of any corrosion, grease, paint, etc. You can spray paint or battery terminal protector or whatever on the connections after it's all bolted up to help keep corrosion out.
Optional: You can use a ground terminal like the Streetwires GT10 on the chassis side... or you can just use a big ring terminal and sheet metal screw... or you can use a preexisting bolt. Just, again, make sure to clean the surfaces.
