Will speakers from a '99 T/A fit an '01 Camaro?
Found some speakers for sale. Was wondering if the speakers from a 1999 Trans Am with monsoon stereo will fit inside my 2001 Camaro also has monsoon stereo. I just need the speakers though, not the plastic overlay piece. Any other stuff I should be aware of for this purchase?
Ungrounded Moderator
They will physically fit but they won't work well. For example, the sail panel subs in a Firebird are dual voice coil (DVC) 4-ohm but the Camaro has 2-ohm SVC subs there. The doors in a Firebird have the tweeters mounted in a separate pod but a Camaro has the tweeter mounted inside the woofer similar to a coaxial speaker (but still separate components).
I wouldn't. There are far better options out there. It would be possible to make the sail panel subs work by wiring the two coils in parallel to produce the proper 2-ohm load but there would be no way to incorporate the separate Firebird tweeters into the door speakers.
he's right...you're better off with aftermarket for the speakers and kee has subs you can put in there....i made the mistake of replacing my sail's with speakers cause i had no idea they were subs...whoops...haha
