Camaro Sail Panel Speaker Recommendations
I know that I'm looking for a 6.5" subwoofer or midbass - just want a speaker that will match the filtered signal that it's receiving. Probably want something thats 2 - 4 ohm and is efficient (i.e., 90db or higher).
By the way, I'm replacing the factor HU with an Alpine CDE 123, but retaining the monsoon amp.
Thanks.
Jim
http://www.keeaudio.com/cdtmidbass.html
Don't rely on a 6.5 in the sail panel for true sub-bass. The excursion would have to be so high it wouldn't fit in that shallow mounting spot.
The other speaker I was looking at was the Kicker 10CVT654. Any thoughts on this one? It's pricey though.
But I do like the idea of going with a mid-bass for the sail panels powered by the monsoon and then a 12" sub in the back with it's own separate amp.
Any other sail panel speaker recommendations besides CDT?
Jim
Jim
So basically I had what you want to do. I tried not having the sail panel speakers and just the sub and didn't like it,felt something was missing. I was happy with the setup I had and will eventually get one put in again.Good luck.
Jim
The kickers would probably be alright but they don't list the sensitivity. I might consider them if I was going with a very high powered amp, but not for use with the modestly powered Monsoon.
And be careful with buying sail panel subwoofers because A. You can't fit ones with overly large magnets (in either depth or width) B. You will get tons of rattles if you have anything serious bolted in there.
Like what I see with the CDT HD-6CF, but just want to know if there are any other recommendations out there. Plus, I've had a tough time contacting someone at Kee Audio. Sent e-mails and made phone calls and all went into a black hole.
