Door and Sail Replacement Question
After blowing out my sail speakers and both door speakers it time to buy some new ones haha. I was just wondering if a 6.5 inch speaker would work in the door and sails also will a 3 or 4 way speaker hook up. I know nothing about speakers/amps etc.I was looking to buy 4 Sony XS-GTX1641 Xplod 4-Way 6.5" 300w Speakers. Would these work, thanks so much ?
I just finished installing new speakers in the doors on my 02 ss with the monsoon system. If you have the monsoon it is a bit tricky because the tweeter is mounted in the center of the 6.5" mid (looks like a coaxial) but they both have separate leads (like a component). The easiest way to replace them yet still retain some high's in the sound is to buy coaxial 6.5" 2 way or 3 way speakers (i bought pioneer 3 way). The problem is because coaxial speakers (tweeter in the center of the mid) only have one lead (one positive, one negative) you need to cut some wires. If you use the lead wires that go to the stock mid speaker and just cut and ignore the high lead, than the 3 ways actually sounded pretty good. Another problem is the door panel, it is a pain in the neck to remove. Good luck if you have any questions let me know. The best resource I found was the Monsoon FAQ thread.
