Factory CD Changer not working
Old Nov 14, 2011 | 05:42 PM
dickeymoore's Avatar
Default Factory CD Changer not working
I have a factory CD changer in the trunk of my 2001 Camaro Z28 and the changer stopped working,it will eject the magazine and when I install the magazine back in the changer I can hear it going through the cycles but it will not work by the controls on the steering wheel like it use to, any HELP.THANKS
Old Nov 15, 2011 | 06:39 AM
wssix99's Avatar
Save the manuals!
Does it work from the radio controls or just not the steering wheel controls? Do the steering wheel controls work the radio OK?
Old Nov 16, 2011 | 05:04 AM
The steering wheel contols are the only way I know how to control the CD changer in the trunk,everything else works great with the sterring wheel controls.THANKS
Old Nov 17, 2011 | 07:25 AM
wssix99's Avatar
Save the manuals!
When you are in CD changer mode, the buttons on the radio also control the changer. (Not every car has steering wheel controls.) Its all in the owners manual.
The scan button skips forward/back. The 4 button changes CDs, and the 5 and 6 buttons fast forward and reverse. You'll see the function written at the bottom of the buttons.
Try those.
Old Nov 18, 2011 | 04:58 AM
Which button makes the changer in the trunk play?THANKS
Old Nov 18, 2011 | 09:08 AM
WhiteBird00's Avatar
Ungrounded Moderator
The CD/AUX button switches between sources (it's labeled CD/PLAY in Firebirds).
Old Nov 18, 2011 | 04:26 PM
wssix99's Avatar
Save the manuals!
How long have you had this car? Did you get an owners manual?
Old Nov 19, 2011 | 11:58 AM
I tried all the buttons on the radio and still not luck with the CD changer playing in the trunk I have had this Camaro for 3 years and have read the owners manual on the changer.THANKS
Old Nov 20, 2011 | 09:39 AM
wssix99's Avatar
Save the manuals!
Cool - sounds like something is hosed, then. If the buttons on the radio don't work, your steering controls are fine. Its either something in the head unit or between it and the changer. (Of the changer itself.)
Old Nov 20, 2011 | 09:51 AM
andrewss's Avatar
Mine would stop working sometimes, I just unplug the power wire from the back of the cd changer in the trunk for a few seconds then plug it back in, works most of the time.Not sure why it does this though!
Old Nov 21, 2011 | 11:13 AM
BS's Avatar
BS
Mine had to be "repaired" twice under warranty. The last time they actually replaced it with a Pioneer changer(actually labelled Pioneer, I know the Factory used Pioneer). And it failed again so now I've installed a PAC/iSimple PXDX with the PXHGM1 and I use My Motorola Atrix to play Pandora Radio, iHeartRadio, and TuneIn Radio.
By Brett Foote | 2026-06-04 05:00:17
