Auto trix window fix question
I'm not sure if its related but I have had battery draining issues over the years and this is the only extra thing I have hooked up that I can think of that might be the culprit. Has anyone else had draining issues with this window fix? I told the dealership to hook it back up as it was with the new motor but perhaps they messed something up with it. Didn't mean to hijack the thread, just curious as it could be related.
I've never had any battery drain issues, and my car sits for weeks at a time. I did the Autotrix fix a while back and I also got a new Optima Yellow Top battery around that time . Never had any issues. Are you sure yours was hooked up correctly?
Autotrix kit, when wired right, will not drain the battery. Heck after my accident my car sat all winter with the battery still connected (forgot to disconnect and then it got buried under a snowdrift), months later when I sold it to someone it started up instantly.
I didn't have the drain issues for a while but then my battery would drain from sitting more than 2 days without running. I thought the amp/sub was the culprit but the amp blew out on a hot day a couple years ago so I took it out and the power strap is currently disconnected from the battery and it still has drain issues. The only other thing I've got connected is the window fix. Currently its got a trickle charger to counteract the drain but I'll have to double check the wiring or find out what's causing the drain before I replace the battery again.
give this a try, saved my window motors, and saved me money
