Good replacement for blown front speaker(s)?
Old Jan 26, 2012 | 07:06 PM
WindyCitySuperSport's Avatar
Default Good replacement for blown front speaker(s)?
looking fora good replaceemnt for my front speakers. i havent even checked where theyre at exactly!
i was thinking infinity but would these fit?
http://www.amazon.com/Infinity-Refer...7625863&sr=1-1
if not what are your opinions on a good front replacement?
Old Jan 26, 2012 | 07:31 PM
02sleeperz28's Avatar
I would like to know as well.
Old Jan 26, 2012 | 07:39 PM
that makes 2, now make our day!
Old Jan 27, 2012 | 07:18 AM
WhiteBird00's Avatar
Ungrounded Moderator
Please read the Monsoon FAQ sticky first then perhaps contact Ian at Kee Audio about his f-body replacement speakers. The door speakers are components not coaxials so you will get the best sound using component replacements.
Old Jan 27, 2012 | 07:22 PM
warriorcustoms's Avatar
In my 95 firebird I had Orion 6.5in components they sounded pretty good @ 50w rms x 4 & the tweeter fit sweet where the factory cover was Looked good The 95 T/A will be getting Polk Audio 6.5 components with 100w rms x 4 I installled the 2nd set in the rear & chucked those lil hissin *** speakers back there lol No middle speakers on that one but this set up is gettin somethin sweet with L7 8s in the rear left & right Components sound way better in my opinion Spend 100 bucks & get components youll thank me later
Old Jan 30, 2012 | 08:20 PM
Blownbayou's Avatar
I have those on order and will be installing them this weekend.... Will let you know
Old Jan 31, 2012 | 06:59 PM
blackfbird98's Avatar
i would say polk 6500dxi's if u want to keep it components, infinitys tend to be be more "bright" which makes them become crackely at higher volumes where as polks have better full range and sound better at higher volume.
Old Jan 31, 2012 | 10:19 PM
bizerk1's Avatar
I got alpine type s, but whatever you do get, run new wire from speakers to headunit. If you have factory amp.
Old Feb 1, 2012 | 12:57 AM
TruBloodTransAm's Avatar
If you're on a tight budget, I would just find stock speakers in the classifieds on here. I sold my a few years ago for next to nothing.
If you want a good aftermarket speaker setup, then WhiteBird is right, you should contact Ian at Kee Audio. I have his f-body speaker package in my car, sounds great, and was easy to install.
Old Feb 1, 2012 | 07:36 AM
Uhh, why? Why would you want to give up amplification and just use head unit power? If you get the right speakers for each position (components for doors, subs for sail panels), the Monsoon amp can be quite effective.
Old Feb 1, 2012 | 07:44 AM
Nick V.'s Avatar
what if someone cut out the monsoon amp when they sold the car, so all you have is
the black wire that ran to the amp and a tall glass of sadness?
(my situation)
Old Feb 1, 2012 | 08:00 AM
(my situation)
Well, wiring around a missing amp is different than deliberately eliminating a perfectly good one.
If the wiring isn't damaged, you could probably get a Monsoon amp cheap in the for sale section here and just plug it in. Remember Camaro and Firebird amps are different so make sure you get the right model.
Old Feb 4, 2012 | 02:06 PM
leadfoot4's Avatar
Assuming you don't have a Monsoon system, they're fit just fine and sound pretty good. Shortly before I parked my Z-28 for the winter, I put a pair of those in my doors, and a pair of the similar, but "shallow mounts" in my sail panels.
No, they won't give you earth shattering bass, as they're only a 6.5-6.75" speaker, but the mids are solid and the highs clear and bright. That works just fine for me, as I have a "performance car", not a "rolling concert hall"....
One note, however. I have an aftermarket head unit (Pioneer), which has more power than an OE unit.
Old Feb 4, 2012 | 06:47 PM
Blownbayou's Avatar
Works GREAT with Monsoon system. Wired mine today and sound is very crisp. Will post pics of how I wired them.
Later
Old Feb 4, 2012 | 06:54 PM
Later
Kool.
Old Feb 4, 2012 | 07:23 PM
Blownbayou's Avatar
Had to cut the tweeter wire from the inputs to make the speaker a "component" style setup. Soldered speaker wire to leads and insulated them.
in the door
both speakers have had it
Old Feb 4, 2012 | 07:25 PM
Blownbayou's Avatar
doing the kicker 6.5 in the panel....... 2 ohm shallow mount. Will post results as well
