Subs for double bass
As far as wiring goes, I use 4 guage at the minimum for sub amps and really prefer to do 0 guage on anything more than 750 watts RMS. Electricity flows like water, your alternator is the pump, so why use a small hose and limit performance and decrease longevity and durability? make sure to use quality wire, none of the Ebay or Amazon stuff! I use Stinger and JL.
As for the cap, its a common misconception that the cap will keep your sub amp from going into protect mode and all these other wonderful things. when it actually is just another drain on your charging system. Meaning Caps are only beneficial when the vehicle has an incredibly stout charging system to begin with, which, except for some diesel's, can't be said for most stock vehicles.
Even in that situation, Caps have nothing to do with keeping current flowing and voltage up, to a point. The Cap is actually conditioning the power so your amp will have less noise coming in to it, which increases efficiency a bit, lets the amp run a little cooler, and lets the system have better SQ. most newer amps have smaller capacitors built in to take car of a bit of this task. but for Caps more is always better in the right situation.
the kord ultra flex speaker wire is the new speaker wire to match the kolossus flex. a good choice to match.
Anyone have a good price/location for a 10W3 for it?
Thanks.
Don't even think about a cap ;-) If you install everything and you seem to be having voltage issues we can fix you right up the corrrect way.
thank you :-)
I know I'm barking up a tree, but I just think it's funny.
So what sponsors have the JL 10w3 in stock and can get me a price?
