Alternator/Battery
Old Apr 3, 2012 | 05:12 PM
lt1stud's Avatar
Default Alternator/Battery
I have recently added a 4 channel amp and speakers to my camaro i have noticed a little change when i come to a stop and my lights dim just a little bit. I have recently built my own stealth box and am getting ready to add a 10 inch sub and another amp so that will draw more power. Everyone that i have talked to says put a red top battery in. I have an interstate battery now and i have always run and interstate battery. so should i run a bigger alternator?
Old Apr 3, 2012 | 05:34 PM
Daniel Richards's Avatar
Go with the bigger alternator, but go ahead and do the "big 3" upgrade as you will need it to fully utilize a larger output alternator, Don't listen to people that say oh just get a capacitor, buying a capacitor is like putting a bandaid on a 6" gash.
Old Apr 3, 2012 | 07:33 PM
bigbomber5's Avatar
What's the "big 3" upgrades?
Thanks
Old Apr 3, 2012 | 10:14 PM
Thanks
Big 3 upgrade is replacing the Battery (negative) to chassis ground, Battery (negative) to engine block and battery (positive) to alternator with new cables that are at least 1 gauge larger ie replace any 8 gauge with 4 gauge, 4 gauge with 2 gauge and so on, when running a high output alternator you need to beef these cables up so they can handle the increased output of the alternator, I am personally waiting for my wire to come in to do mine and I will be overkilling it with all 1/0 gauge wire through the whole system described above. I am also going to replace the 4 gauge that runs from the positive battery to the accessory post where the under hood fuses are incase I decide to relocate my amp power cable on the other side of the car from the PCM (never run your high current cables next to the computer, as it risks frying the computer, it happened to a friend of mine so I know it can happen)
Be careful when picking the wire you choose to do this with as not all brands are of equal quality and there are 2 types of cable (CCA- Copper clad aluminum and OFC- Oxygen Free copper) OFC will cost more per foot put can handle more current. Read reviews many companies use thicker insulation and less wire but still call it whatever gauge based on the outside diameter of the wire.
I ordered my wire from Knukonceptz.com thru amazon they seem to get great reviews on there quality of wire and I will let you know when I get it, also http://www.thirdgen.org/techboard/af...ery-power.html there is a Link there to a guy that will custom make you a kit and he comes highly recommended on that board.
Old Apr 4, 2012 | 12:08 AM
sjsingle1's Avatar
https://ls1tech.com/forums/generatio...lternator.html
Old Apr 4, 2012 | 01:22 AM
Any good ones for the V6 models CS 130 with that long arm to clear the valve cover?
Also to the OP if you wanna reduce the headlight dimming when breaking another thing you could do is go to HID headlights, In my old honda when I had HID's I never had dimming headlights, but check reviews and find a good one, see this link https://ls1tech.com/forums/stereo-el...kit-birds.html for info on switching to HID's and the kit everyone here seems to run.
On another side note one benefit of switching to the redtop is you get the top posts on the battery and that would allow for doing the "big 3" while still retaining all the factory wiring, but unless your battery tests as weak I wouldn't replace it as the redtops runs for like 186 dollars these days, my battery was bad (tested at like 360 CCA basically half what it should be), because the guy I bought the car from hadn't driven it much if any in the last 6 months and we all know what happens when batteries sit to long.
Old Apr 4, 2012 | 10:15 AM
sjsingle1's Avatar
i dont know much about the V6 alt.....but i would bet it is a CS130 with a different external housing than LS1 CS130s.......so you can always get better internals for the V6 alt
Old Apr 7, 2012 | 01:08 AM
Got my cable yesterday and compared it to the 1/0 gauge I bought from a local stereo shop. the blue wire is from the local place and based on my calculations using a digital bath scale weighs in at approx. .279 pounds per foot and the Knukonceptz wire from amazon (the red wire) weighs in at .461 pounds per foot, so I would say its some pretty good wire, will be hooking it all up in the morning. you can seriously feel the difference holding one cable in each hand for what are both supposed to be 1/0 so the blue will be used to double upon top of the factory 4 gauge that runs from the positive battery to the accessory post by the under hood fuse panel.
Attached Thumbnails Alternator/Battery-wire.jpg
