few 2 ohm vs 4 ohm questions
hello all. I was wondering how much volume I would lose by running 4ohm components in the doors with the factory amp, with a good quality set. and would i lose any sound quality?
OR
should/could I get a 2 ohm component set and use the crossover included for the tweeters?
OR
just replace the door speakers and leave the tweeters alone?
thanks in advance
Bruce
OR
OR
thanks in advance
Bruce
You will probably lose about 1/2 power going ti those speakers(not half output thought).sound quality shouldn't be affected in terms of what comes out of the speaker running a diff impedance, it just wont be as loud.
Ungrounded Moderator
In general, if you replace a 2-ohm speaker with a 4-ohm speaker (all else being equal) you will lose half of your power. As johnyko12 mentioned, half power does not mean half volume. Cutting power in half results in a 3dB drop in volume which is about one click of the volume ****. And that's with everything else equal... just about any decent aftermarket speaker is going to be at least 3dB more sensitive (efficient) than the stock speakers so you end up with no volume loss at all.
And no, changing impedance will have no effect on sound quality.
OR
OR
thanks in advance
Bruce
OR
OR
thanks in advance
Bruce
