DRL Problem
Then get a test light or multimeter and check for power on the blue wire at the socket. If there's power there then either the bulb or the socket. If not, you'll have to test at the DRL module inside the dash behind the radio. If there's power there then the wiring between the module and the socket is broken. If not, you probably need a DRL module.
