No Power at OBD2 Port
Couple days ago I cleaned up some wiring, removing unnecessary unused wires from a nitrous kit that was on the car. Didnt remove much, just an unused relay, and some dead end wires. The cig. ligher had a dead end wire comming off of both the power and ground wire. I removed them and reconnected the wires, power to the center post and ground to the outer shell.
After putting it all back together I go to plug my radar detector in and it is not getting any power. This has happened before and after disconnecting and reconnecting the wire it was fine. But this time, still now power. Later on I threw a, I'm guessing p0155 02 heater code, and when I went to plug in my code scanner to clear it, the code reader does not get power either.
I have read that the cig. lighter power or ground or both are also the power and ground to the obd2 so I removed the center consol and started tracing wires but the power and grounds from both cig. lighters dissappear into the wiring harness case and go behind the dash. So the next step is taking out the glovebox and kick panel so I can further trace the wires if nobody can help me..
All fuses are good and everything else is working as it should
So my question is: Where is the ground location for the interior wiring harness? do all these wires go into the bcm?
Thanks for taking the time to read!
Eric
