Sound proofing material?
Old May 20, 2012 | 11:08 PM
6togo's Avatar
Default Sound proofing material?
What is everyone using to sound proof their cars Dynamat? Something better?
Old May 20, 2012 | 11:10 PM
Blownbayou's Avatar
peal and seal from lowes........ did my spare tire compartment (infinity bass link) and it worked like a charm
Old May 20, 2012 | 11:58 PM
bwkmaro's Avatar
roof sheathing from lowes 1/8 thick. 1, 25$ roll did my trunk 1 3/4 times worked great
Old May 21, 2012 | 01:06 AM
emenny81's Avatar
all the stuff mentioned above are asphalt based and if you are in a warm climate city your car will smell, I'm in cali and recently installed raamat and ensolite, remember raamat(dynamat) is sound deadening not proofing you will help with vibrations but you will need ensolite to sound proof.
Old May 21, 2012 | 01:47 AM
Daniel Richards's Avatar
on my hondas I used to do a layer of aerosol "rubberized under coating" from advance auto, it would stink real bad for about a week, and good trick is if there's a spot where to pieces vibrate and its somewhere you don't see when the interior panels are in place you could "spray foam" the small gaps between those pieces, but make sure its out of direct sunlight as sunlight will melt the foam as it cures. Yeah its a bit ghetto but its cheap and highly effective.
Old May 23, 2012 | 10:18 AM
Shane's Avatar
Another vote here for Raammat and ensolite. Good price, great results.
Old May 23, 2012 | 05:25 PM
bayer-z28's Avatar
Sound proofing and dynamat are two different things. Dynamat is meant to reduce vibrations and road noise. Sound proofing would require a closed cell foam to stop the noise.
Something like this:
http://www.secondskinaudio.com/index...y-liner-detail
But I used FatMat Extreme. Was about as thick as Dynamat, but made of a different material.
I did that before. It kinda worked, but it didn't. You can not get the spray coating to lay thick enough to add enough weight to the panel to effectively reduce it's resonant frequency.
Spray foam in tight areas: yes! I'm a big fan of that.
Old May 23, 2012 | 06:34 PM
I don't think I even bothered to do it on the last honda, my brother is thinking about gutting the interior of his prelude and doing truck bed coating, don't know if that would be any better but it would be far cheaper then dynamat and he doesn't have a system so he doesn't need much. But it needs a good degrease before anything happens the previous owners ragged it out.
Old May 23, 2012 | 06:42 PM
EdgarB's Avatar
I have a friend that used window flashing tape for his M3, worked great!
Old May 23, 2012 | 08:05 PM
bayer-z28's Avatar
True, but you can't expect something to work exceptionally for $20. Get what you pay for and I guess it's all on what you NEED. If you don't really NEED heavy sound deadening, then I guess the spay stuff will be fine.
Old May 24, 2012 | 02:47 PM
'00_Z's Avatar
My car sat out in 90* heat yesterday with the windows up and no smell whatsoever. Only have the rear well done though so that might make a difference.
Old May 24, 2012 | 03:05 PM
97FormulaWS-6's Avatar
From: Land of the Mormon's although I'm not one of them
3M rubberized undercoating, foam weatherstripping, and low-expansion spray-foam.
Old May 24, 2012 | 09:17 PM
6togo's Avatar
Sound deadening is what i would want proofing was not quite the word i meant. So it seems everyone recommends/uses dynamat i see they have a extreme version which i dont know is any better and i see eastwood sells their version of dynamat anyone use that?
Old May 29, 2012 | 09:45 AM
T-Top's Avatar
I am kind of wanting to reduce road noise in my camaro too. You guys think four sq ft would be enought Dynamat to do the main part of the cabin (under the driver/passenger seats & floorboard)?
Old May 29, 2012 | 10:56 AM
emenny81's Avatar
I covered most of the doors and panels and used about 75 sq ft of raamat and about 40 sq ft of ensolite
